The possibility of certificates renewal on "master account" without creating new merchant identity certificate and key stores.
Hello! We use Apple's "master account" scheme to register new clients trough API due to the fact that the number of merchant IDs in a developer account cannot exceed 100 records. It's been almost a year since we successfully used the master account ( ex. "merchant.com.xxx") and register clients via Postman. At the moment, the certificates for the master merchant ID start to expire on July 11 which will affect all customers which is under Master ID. We know that when updating certificates at the identifier level(our master id), new universal identity certificate files that we use to send to the merchants (merchant_id.pem, privkey.key) will be generated for authentication on the merchant side, as well as a new keystore. Since many of our clients are integrated with current files and keystores and have live traffic, we would like to know—is it possible to update certificates on the master account without changing the keystores and certificate identities? The impossibility of this will entail a large gap when switching to new certificates. Thanks in advance for your answer.
