We have an application which is written in Swift, which activates Transparent Proxy network extension. We are using Jamf MDM profile for deployment. To avoid the user deleting / disabling the extension from General -> LogIn Items & Extension -> Network Extensions screen, we are using "Non-removable system extensions from UI" attribute under Allowed System Extensions and Teams IDs section.
In new Mac OS 26 (Tahoe), user can also enable/disable the extension from General -> LogIn Items & Extension -> Apps tab. The "Non-removable system extensions from UI" attribute set in Jamf MDM profile does not apply to this tab. Same attribute is working for General -> LogIn Items & Extension -> Extensions tab and there the slider is greyed out and Remove option is not available under more menu. Is there any new key/configuration defined to disable the slider from General -> LogIn Items & Extension -> Apps tab?
Created https://feedbackassistant.apple.com/feedback/18198031 - FB18198031 feedback assistant ticket as well.
