StoreKit 2: jwsRepresentation Validation, Rate-Limit Relief, and Send Consumption Info Effectiveness
Hi everyone,
We operate an online game where all in-app assets are stored server-side and require a logged-in account (no device binding). I’d like guidance on four areas:
  1. Do we really need deviceVerification / deviceVerificationNonce?
– Because every purchase is tied to an account and we enforce a global transactionId UNIQUE constraint, replay or cross-account reuse appears infeasible. Under these conditions, is omitting device verification acceptable, or are there situations where Apple still recommends it?
  1. Permanent rate-limit increase for the App Store Server API
– During anniversary events we saw bursts of ~18 000 requests per hour, breaching the current hourly cap on the App Store Server API (verifyTransaction, getNotificationHistory, etc.). Is there a formal process to request a long-term rate-limit expansion (or an alternative tier) from Apple?
  1. When is an App Store Server API call required for a StoreKit 2 jwsRepresentation?
Docs say “call the API if you’re unsure,” but there’s no clear cut-off. Because we fully validate the JWS signature plus the entire certificate chain (including CRL/OCSP checks) on our server, local cryptographic validation seems sufficient for consumables. For subscriptions we still plan to hit the API to fetch the latest status. Does this separation match Apple’s best practice?
If Apple does recommend hitting the API for consumables as well, we’d like a concrete rule of thumb—e.g. “if the item price is USD 50 or higher, always use the API.” Is establishing such thresholds consistent with Apple’s intent?
  1. Refund-risk reduction from Send Consumption Info
– Adapty reports a 40–60 % refund-rate drop for subscriptions when using Send Consumption Info (blog reference). Can we expect similar reduction for consumable IAP in social/online games? Any real-world results would be helpful.
Thanks in advance for any guidance!
