Attaching depth map manually
Hi, I have a problem when I want to attach my grayscale depth map image into the real image. The produced depth map doesn't have the cameraCalibration value which should responsible to align the depth data to the image. How do I align the depth map? I saw an article about it but it is not really detailed so I might be missing some process.
I tried to:
  1. convert my depth map into pixel buffer
  2. create image destination ref and add the image there.
  3. add the auxData (depth map dict)
This is the output:
There is some black space there and my RGB image colour changes
Are you using code to do that or an app? If you are manipulating the image in code, please post the code otherwise, we appreciate your interest in participating in the forums! These forums are for questions about developing software and accessories for Apple platforms. Your question seems related to a consumer feature and is better suited for the Apple Support Communities
https://discussions.apple.com/welcome
Albert Pascual
