Issues with @preconcurrency and AVFoundation in Swift 6 on Xcode 16.1/iOS 18 (Worked fine in Swift 5)
Question:
I'm working on a project in Xcode 16.1, using Swift 6 with iOS 18. My code is working fine in Swift 5, but I'm running into concurrency issues when upgrading to Swift 6, particularly with the @preconcurrency attribute in AVFoundation.
Here is the relevant part of my code:
@preconcurrency import AVFoundation
struct OverlayButtonBar: View {
    let audioTracks = await loadTracks(asset: asset, mediaType: .audio)
    // Tracks are extracted before crossing concurrency boundaries
    private func loadTracks(asset: AVAsset, mediaType: AVMediaType) async -> [AVAssetTrack] {
        do {
            return try await asset.load(.tracks).filter { $0.mediaType == mediaType }
        } catch {
            print("Error loading tracks: \(error)")
            return []
Issues:
When using @preconcurrency, I get the warning:
@preconcurrency attribute on module AVFoundation has no effect. Suggested fix by Xcode is: Remove @preconcurrency.
But if I remove @preconcurrency, I get both a warning and an error:
  • Warning: Add '@preconcurrency' to treat 'Sendable'-related errors from module 'AVFoundation' as warnings.
  • Error: Non-sendable type [AVAssetTrack] returned by implicitly asynchronous call to nonisolated function cannot cross actor boundary. (Class AVAssetTrack does not conform to the Sendable protocol (AVFoundation.AVAssetTrack)). This error comes if I attempt to directly access non-Sendable AVAssetTrack in an async context :
How can I resolve this issue while staying compliant with Swift 6 concurrency rules? Is there a recommended approach to handling non-Sendable types like AVAssetTrack in concurrency contexts?
Appreciate any guidance on making this work in Swift 6, especially considering it worked fine in Swift 5.
Thanks in advance!
Answered by Dirk-FU in 803688022
Leave the @preconcurrency attribute in and ignore the warning (for now). I heard it is a bug in some version if the compiler betas. Have you tried the same with Xcode 16.0 Release Candidate (Sep 9th)? It should aready have a newer compiler than Xcode 16.1 (Aug 12th).
