I want to use MapKit with App Intents, but the map does not show up.(See attached image)
Can anyone help me solve this?
import SwiftUI import MapKit struct ContentView: View { @State private var region = MKCoordinateRegion( center: CLLocationCoordinate2D(latitude: 37.334_900, longitude: -122.009_020), latitudinalMeters: 750, longitudinalMeters: 750 ) var body: some View { VStack { Map(coordinateRegion: $region).frame(width:300, height:300) .disabled(true) } } } struct ContentView_Previews: PreviewProvider { static var previews: some View { ContentView() } }
import AppIntents import SwiftUI import MapKit struct test20220727bAppIntentsExtension: AppIntent { static var title: LocalizedStringResource = "test20220727bAppIntentsExtension" func perform() async throws -> some IntentResult { return .result(value: "aaa", view: ContentView()) } } struct testShortcuts:AppShortcutsProvider{ @available(iOS 16.0, *) static var appShortcuts: [AppShortcut]{ AppShortcut( intent: test20220727bAppIntentsExtension(), phrases: ["test20220727bAppIntentsExtension" ] ) } }
